lock change
how easy is it to change the locks and ignition barrel on a phase one dt?
also is it expensive to do?
Door locks are easy. whip the door card off and holding the lock in is a metal c shape plate. Pull this out with a pair of pliers and the lock will just pop out.
Ignition barrel is a bit fiddly. You have to take a small screw out then push in a tab on the bottom of the barrel as you turn the key from off to first position.
cheers dude where can i get new ones from.
Ebay
http://www.ebay.com/itm/PEUGEOT-306-DOOR...1c26f4cde7
http://www.ebay.com/itm/Peugeot-306-door...19d3571d11
http://www.ebay.co.uk/itm/PEUGEOT-306-93...2a0e013c74
http://www.ebay.co.uk/itm/PEUGEOT-306-1-...2ec1ada11c
[Image: 62941977.jpg]
  boot lock change. Joe 10 5,610 26-03-2012, 11:54 AM
Last Post: declantg
