Rev counter problem
Rev counter problem
Changed my xud for another but the sensor for the rev counter is different? The hole in the back of the block is there but my sensor wont go in.. Any ideas? Thanks Smile
Bumpity bump i miss my rev counter Sad
open it up? they are all the same.. must not have undone the 10mm bolt enough
What do you mean dave? I took the sensor out of my own block and when i went to put it into my new block there is nothing in the same hole?
Make the hole bigger by unscrewing the bolt that clamps around it
I am having this issue after I changed to a 306 box can't workout where is it.
Stage 2 XUD Sedan
As Dave says really, get some pictures to show us Smile
[Image: J5hxCcC.jpg]
I wont be under the car till later Smile Thanks!
My old sensor was around the back of the block and my new one is a white plug at the front of the engine?
