Threads: 96
I've got a meridian do it car that has electric rear windows and I really want them in my hdi which first have them the card are th saw olive so just wondering if changing the doors over would be a good idea but then I thought is all the wiring in place and if so how do I go about fitting it all I.e fuses etc ?? Just wondering if anyone has any know how with what to do ?? Bearing in mind in ass with electrics :-(
Threads: 178
28
Car Model/Spec: HDi!
Mine had the plugs needed in the centre console where the rear window switches goes... then i just drilled the motors out of the old doors and rivited them into my new doors and swapped the bottom half of the doorcards over as they were different patterns... Was really easy on mine... plug and play as they say!
Threads: 96
Like I said the doors are from a car the same colour could I just swap the doors over ?? Then thread the wiring under the carpet or something to the panel ?? not sure where the wiring runs from the door to the console ?
Threads: 96
I think I've Sussed that the wiring runs through the same loom a the central locking so like u said kat pig in the switches and changer the door over and boom game on !!
Threads: 96
I have all the parts chief sat on the donor car :-) gunna do it tomoz only issue I haven't thought about is do I have to rewire the window immobiliser button in or are the Electrics there ready ?? And do I need to add any fuses to the fusebox or do I really need the rear window immobiliser key switch thingy ??
Threads: 96
Ok so doors have been changed over central locking works but the Leccy windows don't so is there fuse I have to put in somewhere ??
