Aux Belt
Aux Belt
I've got a sqeaking/chirping noise coming from next to the alternator, after abit of searching i've narrowed it down to being the AUX Belt?? and it seems to be quite common on these, i've never tackled fitting one before, is of any real difficulty?? or anything else it could be?
Cheers
Chez ThumbsUp
Nothing too hard mate... Just slacken the pre tensioner and remove the old one, take a note (drawing) off the route that it takes and replace....
You may aswell replace the bottom pulley while your thier as they are common to failure too...
cheers mate, i'll have a look , i know you can pick the belts up new ofc for pennies but what kinda cost you looking at for the bottom pulley?
between about 35 and 100.. depends if you want a light weight one, which will make it rev easier... if not, i bought http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...TQ:GB:1123 which is fine...
http://www.ebay.co.uk/sch/i.html?_from=R...aft+Pulley
Spot on Smile, that add says 206/307hdi?? i suppose all the Peugeot HDi engines run same pullies etc??
Yeah, the later, 307 ones are better built and last longer... Citroen also use the same engine Wink
Did you notice the second link?
http://www.ebay.co.uk/sch/i.html?_from=R...aft+Pulley - That one marra??
(11-10-2012, 01:08 PM)ChezHdi Wrote: http://www.ebay.co.uk/sch/i.html?_from=R...aft+Pulley - That one marra??
your link dont work mate
Now it does ThumbsUp Big Grin
http://www.ebay.co.uk/itm/Peugeot-206-30...19cc60b44b
I bought that one from that seller...
Quote:I bought that one from that seller...
Was that the other link you put on or. Cause i couldnt see anyother than the link for the item itself.
You say chirping noise, that's generally more related to a worn pulley, tensioner or power steering pump bearing. Worn aux belts usually make a continuous squealing noise when you first start the car in the morning, or after driving through a big puddle for example. I would say it's worth rotating all the pulleys and tensioners by hand while the belt is off to make sure all of them rotate freely and there's no feeling of stiction/graunching in the bearings.
this one mate
Cheers poodle will do, Thanks for your help Sean.
