Threads: 42
0
Car Model/Spec: 1.8 16v
Given 0 thank(s) in 0 post(s)
I am currently miss firing under 2000 revs when i poke the go pedal will it make my cat colapse i had a simillar problem with my 406 2.0 turbo and the cat collapsed Cus of the unburnet fuel exploding in the downpipe and thoughts will be appreciated
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
I had a cat collapse on my 1.8 16v so it's not out of the question. If you're concerned about it then don't drive the car until it's sorted.
If it's a missfire then check the sparks first.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 18
1
Car Model/Spec: Black ph2.5 Dturbo
put a de cat on, diesels dont need them anyway...
Threads: 208
60
Given 5 thank(s) in 5 post(s)
sounds like it needs the problem sorting rather than worring about the cat
