Indicators have turned into hazzards!
Help someone! I dont know whats going on.... battery died in the same evening i noticed the problem it was after the battery died the problem started :/ The relay is still clicking its just all the indicating lights are going off instead of just one side Sad
Will be the alarm i expect mate tried the button on the right of the steering column? And are the headlights flashing when you open a door?
Nononono you misunderstand, when i indicate they all flash instead of the side im indicating towards! I did a real shit job explaining :/
mine did that with the alarm too Tongue may be a buggered relay?
Also this was after id had the battery out to charge it
Im going to go unlock and lock and press that button and bugger round now! If your right i will shake your hand sir!
i would say its your indicator relay..
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
Still nothing.. I have noticed that my hazzards dont flash when i lock and unlock anymore??
faulty caution lights button? everything goess through that so if its broken then that might be a problem?
(05-10-2012, 06:18 PM)SRowell Wrote: faulty caution lights button? everything goess through that so if its broken then that might be a problem?
That appears to work fine Undecided
sounds f*cked mate
(05-10-2012, 07:00 PM)samass Wrote: sounds f*cked mate
Cheers (y)
Forgot to check the battery voltage, just went to start it and nothing == what a fail
Jump started this morning, left it running went for a drive and its all fine haha so let that be a lesson to everyone always check you battery!
  Indicators and Hazards not working. CaptainHair 5 6,132 19-01-2020, 06:47 PM
Last Post: CaptainHair
  indicators wont work :/ hilly5672 2 3,224 24-05-2016, 10:48 PM
Last Post: hilly5672
  no indicators Leemus 4 4,930 22-06-2015, 09:07 PM
