load valve pipe locations
on this new beam ive got the brake pipes have been cut from the load valve, does anyone know what pipes goes where as im going to make and fit the new pipes for the beam before it goes on i know the one for the drivers side goes to the rear right hole as this one hasnt been cut ???
Front two ports are the IN, Rear two ports are OUT. Left and right is left and right.
[Image: KrisB-new-Logo11.gif]
sweet cheers mate
Dan Wrote:on this new beam ive got the brake pipes have been cut from the load valve, does anyone know what pipes goes where as im going to make and fit the new pipes for the beam before it goes on i know the one for the drivers side goes to the rear right hole as this one hasnt been cut ???
As Kris said.
This is from a thread I posted on .net
[Image: sam1hgjhj495.jpg]
HDi Cabby Project Click
Cheers mate
  Brake pipe routing with manual bias valve Lolben91 15 3,342 26-04-2015, 09:23 AM
Last Post: adam b
  bypass brake load valve blinkyeatu 0 842 05-02-2015, 05:51 PM
Last Post: blinkyeatu
  Lowering and load sensing valves. bashbarnard 17 3,496 30-10-2014, 10:41 AM
Last Post: Toms306
