Threads: 87
31
04-10-2012, 06:11 PM
(This post was last modified: 28-12-2012, 08:55 PM by Dan!.)
As some know we've been builing a new garage recently, and as a result I should be able to start offering my services again, LDA grinds, Injectors refurb and calibration etc. + more.
I wont be able to start for a few weeks yet, but im putting this up now to drum up any interest and let everybody know in advance. If you have any requests or want any other bits done which might not be listed then feel free to post/pm me.
Main stuff will be;
LDA pin grind - £15
Gov mod - £25 off the car/£35 on car (includes pump setup/fine tuning)
Injector refurbishment (Full strip down, all parts cleaned and pressures calibrated) - £8/injector
Injector refurbishment + new nozzles - £24/injector
Cambelt change - £80
Cambelt + Bosch fitting and pump setup- £115
Turbo change - £120
Can also supply almost any pump or injector parts (gov cradles, fuel screws, lda housings, leversets etc) Just PM me with your request and il get back to you with a price.
Also, can offer any custom work like exhausts/bodywork etc, but again PM me with details and il work something out.
Also, im not sure what the deal is with 'trading' on here, but il PM Scott in a bit and I intend to donate 10% of any sales which are conducted through the forum.
Thanks, Dan.
Threads: 170
are you doing this from home?. shame your to far away i wouldnt mind another pump putting on. mine got rust in there and for 20psi it smokes alot
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 87
31
Some stuff will be work related like supplying replacement pump parts/injector nozzles etc, but all vehicle work is done at home and entirely outside of work.
If you feel like having a drive down then let me know man
Threads: 0
45
See my exhaust thread for your first booking <3
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Amazing news, expect a set of injectors for refurb/nozzles from me
Threads: 155
11
Car Model/Spec: Bianca DTurbo
(04-10-2012, 06:29 PM)JJ0063 Wrote: See my exhaust thread for your first booking <3
Don't think so boyo! Had my td04 turbo change down for a while now
Threads: 87
31
You still have no adapter plates or oil line Mowle
Thanks Jordan and ZX
Threads: 55
Will be needing LDA grind soon, I'll send you a message when it's ready bud!
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 155
11
I tried finding that place for the steel today but got very fu*ked off with people's driving round Yarmouth! So I'm going back tomorrow. I'm waiting on a phone call from you to say we can go get the oil lines!!!!!!
Threads: 87
31
Yeah im waiting for a call from the Pirtek man about oil lines aswel. Make sure you get stuff that is 8mm thick and about 30cmx30cm minimum.
Threads: 155
11
I've got a text from Ben with all the info I need to get them just need to look for the place properly.
Threads: 202
58
I assume this is all for XUD's, or can you do HDi injectors?
Threads: 87
31
Jonny - Yeah these prices are for xud/mechanical injectors only. We do do common rail injectors at work, but the prices won't be anywhere near what I'm charging as it will be all legit through work etc.
Threads: 202
58
Go on.. how much?
Threads: 87
31
Dont know off the top of my head, I barely ever do the CR injectors at work. I can find out for you tomorrow
Threads: 38
Am after a ground lda pin,
Threads: 26
Car Model/Spec: 205 Mi16 and 306 HDI
Injector refurbishment (Full strip down, all parts cleaned and pressures calibrated) - £7/injector
Im interested in this
Threads: 94
Ill be sending you a pin in a few weeks
Threads: 124
26
Car Model/Spec: Megane DCiR
Think il be gettin injectors with new nozzles very soon then just got to fond some spares in scrappers so not off the road cracking prices them dan!!
Threads: 87
31
Threads: 289
92
Car Model/Spec: Phase 17 R26
Stuck this thread for you Dan
Threads: 110
20
can you provide a LDA pin already grinded?
Threads: 87
31
Yeah sure, although I'd be looking at £20 for one as I would have to source a pin first, where's the £13 price is for an exchange pin.
Threads: 150
14
Car Model/Spec: 306 HDI
I can vouch for dans work, absolutely spot on and decent prices
306 HDI, soon to be XUD
Threads: 15
Car Model/Spec: ph2 nile DT + sigma '6
I will be interested in having my lda ground and gov modded when you start doing the work mate, pm me when you start cheers
Threads: 124
26
got a spare pin i can send Dan and just knock a couple of quid off my bill for injector refurb when i get round to it saves you sourcin one lol
Threads: 198
135
I can vouch for Dan's work too, pre-Robocop-arm-incident.
Should be even better now with his precision hydraulic limbs
Threads: 110
20
(07-10-2012, 08:30 PM)Dan! Wrote: Yeah sure, although I'd be looking at £20 for one as I would have to source a pin first, where's the £13 price is for an exchange pin.
ok bud, so what sort of price you it be for you to provide and grind a pin for me? i want to keep standard 1 just incase i ever want to put it back in.
Threads: 87
31
07-10-2012, 09:05 PM
(This post was last modified: 07-10-2012, 09:06 PM by Dan!.)
Thanks for the kind words fellas.
I'll make sure I post in here and pm all interested when I'm ready. Got the garage roof on today, lighting all up and the work bench built!
nufc4frosty ' Wrote: ok bud, so what sort of price you it be for you to provide and grind a pin for me? i want to keep standard 1 just incase i ever want to put it back in.
Sorry man, my post wasn't that clear - £20 to supply and grind a pin, including postage.
Threads: 198
135
In fact Dan I think I still have my spare pin here if you want it?
Sure you'll do me a favour in return one day
