Threads: 541
124
Hello everyone, I have a set of Brembo Calipers off a Fiat Coupe. THESE WILL NOT FIT A 306! as they have 130mm mounting holes not 80mm that the pug has but other than the calipers are identicle, they even take the smae pads and they are fitted ith mintex 1144s that are new but "shop soiled"
Looking for £100 Posted or £80 collected
Threads: 9
19
Car Model/Spec: Ph2 DT with big Snail.....
Why not just make a mount with the correct spacing and fit them to your cabby??
Threads: 541
124
Now on ebay at £120 but ill honour the lower price to anyone here
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
i offer a mars bar and a REAL bumble bee onesie, i find it hard to believe you would turn this down.
Thanks.
Phaes 1 GTI 6 - Onyx Black
Threads: 169
91
Car Model/Spec: 2003 Jaguar S-Type Sport 3.0V6
Very interested in these Dum-Dum.
All that would be needed to fit them is a 130mm mount machined? Are there any available to buy? Or designs available? As my old man has CAD/CAM at work and has done similar things for me in the past...
Also do you have pics of them please?
Threads: 169
91
They look clean, all the pistons move freely etc? No play or excessive rust?
I take it they sit at the correct diameter, but just need the bolt holes further apart?
Threads: 541
124
I assume they work, I have no way of testing the calipers, they are very clean and defo no rust as theyer ally calipers. Theyer actually lighter than standard 266mm calipers.
They are identical to the 406 calipers bar the bolt holes being too far apart. there are ~130mm apart, the pug ones are ~80mm apart
Threads: 169
91
Ok, ill take them off you Dum-Dum, can i pick them up at Aces on the 16th?
Threads: 541
124
You can have them at the tunnel run on the 13th. Do you want the discs as well?
Are you definite gonna 100% have them and ill end the eBay listing
Threads: 169
91
Ill take the discs too, and yes 100% mate. Forgot about the tunnel run....div lol. Yeah ill take them then mate
Threads: 541
124
Right Auction ended mate. Theyer ready for you for the 13th (or if you want to collect them before)
Im going to farnborough to get my new car on tuesday morning if your local to there and want them soon
