Standard high pressure oil line diameter
I'm getting a flexi line made up this afternoon for mowles td04, I know the banjo on the turbo end is 10mm, and it wants to be about 12" long, but what size compression fitting will it want to fit on the old oil line? Cheers, Dan.
i think Jenks knows . . :-)
Ey! You coulda told me I was gonna see if we could get money off for 2! And I havnt been able to start our adaptor plates yet because the plate I have at work is only 100mm, needs to be 120mm Sad
[Image: 20120704_212316.jpg]
I'll get 2 made up when I order them if you want mate? You must have a spare oil line you could vernier for me somewhere? Hopefully order them tomorrow
8mm (i think)
14l male x3/16" is the union to k14/t2 standard line
Compression fiting 8mm or 3/16"
www.prestige-auto-care.co.uk
OD is 8mm
  Help repairing/replacing high pressure PAS pipe heyitsroth 2 3,195 03-01-2018, 11:53 AM
Last Post: welshpug
  Twin turbo high pressure oil feed setup. 205dtub 17 9,107 23-02-2015, 07:47 PM
Last Post: 205dtub
  auxiliary belt length with different power steering pulley diameter juz22 1 2,641 18-10-2014, 05:02 PM
Last Post: Niall
