Valve Clearences
Valve Clearences
Basically my valves are too tight causing a drop in compression.. Did a compression test and the results are as follows..
35, 26, 25, 22
Would it be worth setting the valves clearances by getting the pieces shimmed or will the problem just reoccur in future? Thanks for any help Smile
Bump..
