remote locking broken
unlocked my car went to the shop got out went to lock it and Wouldnt lock on button new battery in the key fob still nothing. Is there a fuse somewhere i cant find a blown one or a diagram of the fuse box can anyone help
Fuse 14 & 28 is for the central locking but if it all works with the key it wont be that. Try retuning the key fob.
HDi Cabby Project Click
(20-09-2012, 05:39 PM)londondan86 Wrote: Fuse 14 & 28 is for the central locking but if it all works with the key it wont be that. Try retuning the key fob.
How????
Switch ignition ON.
Press and hold lock button for 10 seconds.
Switch ignition OFF.
Remove key from ignition switch.
Wait 5 seconds.
Done
(20-09-2012, 05:52 PM)vlj Wrote: Switch ignition ON.
Wait 5 seconds.
Done
Works fine with key in ignition but nothing when out
It helps if you have a spare key to put in the ignition then turn it on. Use the ir key, point it at the sensor by the interior light and hold the button for 5 seconds then turn ignition off. Done
Check this tread out
How I fixed the central locking on my Peugeot 306
[Image: 62941977.jpg]
French sack problem was in my stereo some muppit put yellow and red together so would work without key in swapped them back to how it should be and it works perfectly so dunno if that was tripping the sensors but it works perfectly now at 100yds
  Universal remote central locking carrot 1 4,045 19-02-2021, 07:58 AM
Last Post: Mighty306
  Remote central locking reprogram stranter 2 3,884 23-06-2019, 08:08 AM
Last Post: Toms306
  PH3 remote central locking key replacement cully 4 5,765 29-01-2017, 09:33 PM
Last Post: daniel909
