Injector problem
Injector problem
As it says in the title I've got a problem with the pipes on the injectors the rubber return pipes I think the the first injector cam belt end the pipe goes to the fuel return and they are all linked together until the end injectors gearbox end the last pipe goes to nothin and I think diesel leaks out slowly I was just wondering were the pipe was ment to go any advice would be help full thanks Sam
The gearbox end one doesn't go anywhere. If you got the leak off pipes from Halfords, included there should be two little plugs, pop one of those on and shouldn't be any leaks.
Theres no pipe on the end, theres a blanking end.
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
http://306oc.co.uk/forum/thread-3089.html ThumbsUp
HDi Cabby Project Click
Thank sorted it now thank for the advice
