18-09-2012, 03:14 PM
I need both pipes that come off the PAS pump on a non air-con d turbo.
Would be great if I don't have to go to the scrappy for them!
![[Image: 20120704_212316.jpg]](http://i789.photobucket.com/albums/yy175/DanHargrave/20120704_212316.jpg)
PAS pipes
Would be great if I don't have to go to the scrappy for them! ![]()
19-09-2012, 11:08 AM
Ben,
Currently dismantling a '94 XRDT (non-AC), I presume they'll be similar. I'll try to take some photos this evening and post. ![]() The Old_______and_______Slight Less Old
19-09-2012, 03:41 PM
Excellent that'l be what I need, I presume the pump is below the alternator? And one pipe goes up to the fluid tank and the other goes under the sump, to the steering rack I should think?
19-09-2012, 06:21 PM
Yes to the PAS pump being below the alternator, 1 pipe from tank to pump and the other then disappears down the front of the block and then aft under the sump in the general direction of the steering rack.
![]() Sounds like you have the same set up as me. I've PM'ed you with a few more phots to confirm same set up. Smiley ![]() The Old_______and_______Slight Less Old
