head re skim?
head re skim?
Going to re do my head gasket as it went wrong because I'm useless! I take it my head needs to be skimmed again, even though its barely done 50 miles?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Along as the surface is still flat clean etc I'd say no. It was only 50 miles after all.
I've known someone to put an I skimmed head on, ran better than before lol
Have you took the head off? what was causing it can you see any tel tale signs on the gasket/head/block?
if its not done many miles i cant see needing to getr reskimed i had this in the past and just used sandpaper and block and a quick wipe over it
has it got very hot when running shite? jjust thinking if it has it could have warped the head it may be worth getting a pressure test
someone will be along soon to clarify
[Image: J5hxCcC.jpg]
Just use some 120gritt and some water she'll be fine
Wont need skimming again provided it was done correctly in the first place, just clean it up perfect again..
Did you get the head pressure tested when it was done before? Seems odd that its failing already?
Yeah was fully re conditioned, skimmed tested etc. I think I didn't clean the block properly, its burning coolant and badly pressurizing it..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Does seem strange though how is the water pump?? i know a friend who had similar problem but not on a 306 and he got away with changing the water pump and it solved the problem as the coolant wasnt being pushed around efficiently
Also another thing to check is your heater matrix take pipes off and put a hose to one side and see how the flow if through as as per Ruans thread of 'DO NOT BYPASS HEATER MATRIX' i had several headgaskets when i didnt realise the heater matrix was blocked so bad it kept causing head problems
Worth a check
let us know what you find
CJ
I've had mine go in about 50 miles. It was because of a crap gasket tho
Water pump was fitted January, so should be good. Used victor reinz gasket too. When it runs it sounds as if its missing ever so slightly, and bluey coloured smoke, but not that much. Coolant isn't going down either. Haven't checked the matrix but it blows hot and cold fine with no leaks..
Just about to put a new fuel filter in and shove a load of injector cleaner in with it.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Gave it some more stick today and didn't go well, huge pressure in the coolant, almost at bursting point I would imagine, and a nasty squeek started from the belts area, no idea what it was, only.did it for a few seconds though buts its enough to worry me. I have re bled the coolant before I drive home incase it filled with air or anything.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Sounds like you need to pull the head again
  Head skim? martyn92 8 5,397 06-06-2013, 09:01 AM
Last Post: martyn92
  Skim and Crack test preperation Marcus1991 5 3,572 06-03-2013, 11:42 AM
Last Post: Marcus1991
  Recommend pistion skim Daniel306 7 4,666 09-07-2012, 09:48 AM
Last Post: CJ_Derv
