Leaking turbo? Where to get new clamp??
Hi guys got a TD04L and the clamp that holds cartridge into the hotside seams to blow a bit of smoke on low revs doesnt seem to do it when high revs,
Have had a good look and can only think the clamp has gone, havent tried nipping up yet tbh
Any ideas where to get a new clamp from and whether id need to split it and seal it with anything or just get new clamp n tap it home a tad??
Cheers
[Image: J5hxCcC.jpg]
You sure its that? It'll do it low revs 'cos your pressure is higher then, and as it spools and releases pressure it'll stop, but your EMP is gonna be high on full chat. Are you sure its not just your elbow onto downpipe?
i just took it garage to be honest and he had a quick look and said its coming from there but im unsure i may take exhaust off and put a bit of high temp sealant in and see if it cures it,
i think he think it may be coming from there as it puffs upwards but i suppose that could be the elbow exhaust connection blowing across and upwards
smoke does rise cj Tongue
(19-09-2012, 06:16 AM)Joe Wrote: smoke does rise cj Tongue
No wayyy haha Tongue will investigate this further haha
  Td04 leaking through hotside of turbo? Mike 3 3,244 05-10-2013, 01:28 PM
Last Post: Dave
