HDI FMIC Set-up
Wanted: HDI FMIC Set-up
As above really, Got abit of money to spend and decided to bypass the stage 1 and just go straight to stage 2. Any "Bolt on"" kits available without having to piss about buying various pipes ect?
Cheers, Pete
http://www.ebay.co.uk/itm/251141650402?s...1423.l2649
you`ll use 3 of the pipes, but they are the main ones. then you`ll just need the cooler and a few elbows
I've got a brand new intercooler if it's any use to you. This one:
[Image: u3y2uheb.jpg]
Also for the lower pipe, use a 90 deg 45 to 51 reducer off the turbo. Then some 2" pipe with a 67 (iirc can check) bend in it to get to the front of the block.
This sits up nice and tight on a 306 but does require the tu mount on the subframe to be bent a tiny bit.
I ordered my pipe form a company on ebay called pipeworx, has a 1m bit of pipe with the bend in the middel and cut it down approperatly. Cost £20 quid plus delivery.
[Image: sig.jpg]
Cheers guys, Spotted those pipes on ebay..there was a similar kit in Hudderfield but I cant find it now! Guessing most of the 306 pipework will fit but it'll be going on the van so they could be differences. I'll get back to you Sam once I've had a look to see how much room I've got to play Smile
No probs mate, I've done a few hdi fmic's so if you need any help just give me a shout!
(06-09-2012, 05:32 AM)neilz85 Wrote: http://www.ebay.co.uk/itm/251141650402?s...1423.l2649
Outbid by a tenner Sad
