Rear Beam Rebuild kit, Group Buy
Just looking to gauge interest on a group buy of a "kit" seller is wanting £95 if i buy one but il see if he can do it cheaper if there is more of us, put you name down if you are genuinely wanting in
Comprising Of
Outer Bearings x 2
Inner Bearings x 2
Crossmember Seals x 2
Outer Seal Cups x 2
Suspension Arm Seals x 2
Crossmember Seals Ext x 2
Torsion Bar Studs x 2
Eccentric Washers x 2
Torsion Bar Torx Bolts x 2
1. Daniel306
2. R242_GBU
Price dependant I might be interested, also are they genuine parts? Any reviews?
Iv been told they are genuine, il make sure first tho
If they are genuine then I'll have one
[Image: SDC10442-1.jpg]
Make sure the shafts are in good condition before replacing any seals, if they're not, you're wasting your time, the shafts are fecking expensive, too!
has anyone got the part numbers for
Outer Bearings x 2
Inner Bearings x 2
Outer Seal Cups x 2
  Rear beam ...the good and the bad Mighty306 35 31,563 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,427 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,920 18-03-2019, 03:40 PM
Last Post: MOK
