04-09-2012, 04:06 AM
Just wondering what the deal is with smooth bonnets and washer jets?
Smooth bonnet
04-09-2012, 08:17 AM
WTF? How do you mean?
Do you mean smoothing the washer jets off of the bonnet and re-locating them to the scuttle panel? I'm sure it could be done but I'm not sure it would be worth arsing around with. Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
04-09-2012, 09:13 AM
99% of people leave them where they are. I did and by the sounds of things so CAR. Like he says i aint worth the arsing about and also i think it looks better left there if you put xasra/307 mist jets in anywat
04-09-2012, 09:31 AM
Lol I've just bought a smooth bonnet and there's no holes for the washers! That what i meant haha. Sorry should of been clearer. Shall I just drill a couple of holes? What u mean mist jets and 307 jets mate. Not seen them?
04-09-2012, 09:44 AM
colour code your jets, that's what i did with the last old car, will get round to it on this one too . .
04-09-2012, 10:54 AM
(04-09-2012, 09:44 AM)Mattcheese31 Wrote: colour code your jets, that's what i did with the last old car, will get round to it on this one too . . Matts pink ones looked good
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
The bonnet is completely smooth. No holes for the jets.
Was basically Askin if I'm gonna have to drill holes through it
04-09-2012, 05:57 PM
Surely you will be able to see where the holes were on the underside? It'll only be filler get a screwdriver through it
DONT stick a screw driver though it you will flake the pant on the top side. Try to locate the filler on the top and drill them back through gentely
And mist jets xsara or 307 ones are much better form of washer jet that are a straight swap with no modding needed to make them fit and they also work better
04-09-2012, 07:23 PM
Oh right
and I'll have a look when it's back from getting sprayed. Wish I'd done it before it had gone
04-09-2012, 07:42 PM
(This post was last modified: 04-09-2012, 07:43 PM by Mrs puglove.)
Would of been a bit more ideal to do it before hand TBH
This is from puglove btw ^^^ the mrs leaving her self logged in again lol ![]() 138 BHP XSI
05-09-2012, 04:10 AM
I know
didn't realise til I dropped it off. Will text him later see if he has sprayed it yet
05-09-2012, 09:52 AM
Can anyone tell me what size hole I'll need to drill? He hast sprayed it yet thank god haha
05-09-2012, 12:02 PM
Its not just a hole, there's a notch in it as well, would be best to get another 306 and pop the washer out to copy it
05-09-2012, 12:39 PM
just relocate them to the scuttle panel and be different
Not worth the risk now youve sprayed it up!
05-09-2012, 04:56 PM
The guy hasn't sprayed it he's gonna drill a hole in it before he sprays it and I'll make it bigger if required then use a file or something for the notch. Wouldn't have a clue how to put em on scuttle panel mate
06-09-2012, 05:44 PM
Jobs a gooden then, lucky that!
And the Better washer/mist jets i was ttalking about http://www.ebay.co.uk/itm/CITROEN-XSARA-...19d498272e
09-09-2012, 06:14 PM
Dont use the xsara jets, they aim too low on the windscreen. Iirc the 307 ones are perfect.
09-09-2012, 06:31 PM
I'll get some off eBay when I get the bonnet back. What's the difference in 306 and 307 jets though?
09-09-2012, 06:54 PM
The 306 jets just squirt 2 streams of water at the screen whereas the 307 ones mist it on.
09-09-2012, 07:05 PM
(09-09-2012, 06:14 PM)londondan86 Wrote: Dont use the xsara jets, they aim too low on the windscreen. Iirc the 307 ones are perfect. I found there to be no differece and several places across the tinternet list xsara/picasso/307/207 ETC ETC as one item so im assuming they are the same part, and mine are from a 307
10-09-2012, 07:02 PM
you want the ones with the part number ending V8
23-09-2012, 07:36 AM
| Bonnet smooth | David | 6 | 3,741 |
28-05-2012, 11:33 AM Last Post: David |
