205 low boost 3dr gear pull
Video
Here's a quick vid of the 205 it's only boosting about 25psi so it's nothing special it's just while the clutch is bedding in but a few people have been demanding some speedo vids.
http://www.youtube.com/watch?v=aFAvuI_OZ...e=youtu.be
Stage 2 XUD Sedan
......What's that slip @45mph Sad
Niiice, so your rev counter isn't working now?
That vid was during the bedding in process, it got better and better each time and probably still isn't fully bedded in yet.
Stage 2 XUD Sedan
Looks like it goes well tbh Big Grin
My rev counter sits it the same place, any idea why it dose not work?
Only because at the time of putting in the '9 box I hadn't realised the sensor didn't fit. Just need t ore-wire this new sensor in.
Stage 2 XUD Sedan
(30-08-2012, 06:05 PM)strictly_derv Wrote: Only because at the time of putting in the '9 box I hadn't realised the sensor didn't fit. Just need t ore-wire this new sensor in.
get your finger out max, anyway is this back to how it was now after the smash?
Nearly, I just need a new wing but can't afford that ATM Sad
Stage 2 XUD Sedan
(30-08-2012, 07:05 PM)strictly_derv Wrote: Nearly, I just need a new wing but can't afford that ATM Sad
can you get hold of one max? i could have look and see if the 205s are still at my scrappy. i could price it and see what the crack is with postage?
Appreciate the help but they are virtually impossible to remove with-out damaging as they are bonded on on non-GTI's....hence why this once's a shitter. But if then can remove them i'd be very interested for a white one. Cheers
Stage 2 XUD Sedan
(30-08-2012, 07:09 PM)strictly_derv Wrote: Appreciate the help but they are virtually impossible to remove with-out damaging as they are bonded on on non-GTI's....hence why this once's a shitter. But if then can remove them i'd be very interested for a white one. Cheers
got no chance of a white on max sorry, id have to remove it for you, are they fully bonded on? be away of getting it off with out damaging the wing.
Iv got two gti's and a Dturbo and they are all bonded on
Thanks anyway Procta.
What do people reckon the power output is in the vid? I gotta keep it under 150bhp Sad
Stage 2 XUD Sedan
That was pretty much a 30-70 wasnt it? What time did you do it in?
max you want me to have a look at a wing?
Looks about 7 seconds with lag due to being in 3rd and a little clutch slip, so not very impressive. I will do an actual 30-70 vid soon.
Yes Procta if you could have a look it would be much appreciated Inlove
Stage 2 XUD Sedan
  Samass on the pull Grant 8 4,028 15-11-2013, 09:31 AM
Last Post: Matt
