Rear light cluster issue.
Right passanger side rear cluster is driving me crazy.
Drivers side is all fine, basically the running lights don't work.
Reverse fine,
Brake fine,
Indicator fine,
Fog fine.
I have swapped the bulbs from one side to the other no issues with bulbs.
I have also noticed the number plate bulbs aren't working.
So far I have re wired the number plate lights, changed the connector for the number lights, which plugs into rear light connector.
Any ideas? Could it be a fuse? If so which one save me checking them all.
Lights have been earthed in the past.
Have you checked to make sure the earth is good? And checked for corosion on the board the bulbs go in to?
Also check the plug that runs off the drivers side light to the pas side
No board. Sorry should have said phase 1 lights.
Earth has always worked before.
There is a board on phase 1 lights that the bulbs go in to its plastic with metal runing around it. It pops off the light unit so you can change the bulbs mine was badly corroded
I'd take the earth off give it a bloody good sand down on both surfaces an give it another try
  Brake light switch issue Iceman299 4 3,893 26-07-2015, 02:01 PM
Last Post: Iceman299
  Phase 1/2 rear light wiring diagrams. ADV_93 1 2,685 04-09-2014, 02:45 PM
Last Post: doogle-d turbo
  Phase 1 rear light wiring PartyJas 1 1,905 10-07-2014, 12:29 PM
Last Post: Frosty
