11mm pump mod info needed
Could u use the 11mm head out of a fly by wire pump off a renault dti and put it in the 1.9 td ve pump cos i could get a fly by wire pump for free any help would be greatfull ive used transit pump and done it befor but cant get hold of a pump cheap enough at the min thanks
is it a bosch ve pump? if so then its just a distribution head so should be fine?
  11mm pump build EngineEngineer 4 6,142 21-02-2019, 12:38 AM
Last Post: Dave
  Bosch pump experts needed! 205dtub 8 7,230 28-09-2017, 04:55 PM
Last Post: da_no1
  Squeezing more power out of an already maxed out 11mm bosch pump Paul_13 28 18,133 07-05-2017, 08:02 PM
Last Post: Paul_13
