28-07-2012, 03:53 PM
Right, having crashed my dturbo due to some twat on the motorway causing me to swerve and lose the backend, the insurance wrote it off as a Cat C and I bought it back.
I have now completely stripped the car to a bare shell and need to get rid of the parts to clear space for my project car.
Bits that are NOT available:
Engine (don't mind splitting intercooler, inlet, and lucas pump etc off this) but the block and head are staying)
Wiring loom (internal and external)
Nearside front wing (accident damaged)
Nearside door (accident damaged), although this could be stripped for bits
All panels are Platinum Silver (MOYC code) and parts are collection only unless it's small enough to wrap and post (shoebox size ish)
Prices are o.v.n.o (ask, I can only say no) and will be + postage which I will have to find out once packaged:
Oily/exterior bits:
Drum beam, solid, no camber issues, had new bits for mot a month before I crashed it, handbrake cables (up to lever) and hard brake lines still attached: £100
Gearbox: £50, standard Dturbo box, no crunches/whines etc.
Struts (good bearings and driveshafts still attached): £20 each or £35 for the pair
Complete towbar assembly with new twin electrics kit and standard ball: £150
Bumpers: £30 each or £50 for the pair, both in good shape, maybe a couple of minor marks
Offside drivers door complete (blue fleck door card, door bin, electric window + switch, manual mirror, hinges etc). This will need a new lock as some scrote has prised out the lock but there are no marks on the door itself: £50
Front subframe with 2x wishbones (P bushes will need replacing soon): £30
266mm front brake kit (lucas calipers with brand new disks and pads, literally done about 500 miles, disks now have light surface rust): £150 complete
Stainless steel braided lines for front brakes (good make and made to measure for the application): £40
Rad (seems perfectly fine): £10
Twin fan assembly (worked fine): £20
Slam panel (bare): £10
Headlights: £10 each or pair for £15
Rear lights complete with good boards and backing plates: £10 each or pair for £15
Tailgate with spoiler, wiper motor and working heated rear screen: £20
Fuel tank with all piping (inc hard lines) up to the engine connections, filler neck assembly, fuel pickup and fuel gauge assemblies: £40
Bonnet with felt liner (couple of light scratches): £25
Interior bits:
Seat set complete: £30
Dashboard (minus the centre part which is colour coded to the car, the wiring loom, and the heater controls): £20
Heater control panel: £10
Dash centre panel (uper and lower): £10 (cost me this in paint and lacquer)
Carpet (standard grey, both bits): £10
Light grey roof lining (bit dirty but nothing that wouldn't clean off): £10
Electric sunroof assembly, no leaks: £30
Bulkhead sound deadening: £5
Pedal box assembly: £10
Upper steering column with wheel and ignition barrel (one key): £10
Column surround with stereo remote control and ultrasonics button: £15
Seat belts (standard black): Offers?
Pop out rear windows with large theywhoshallnotbenamed stickers in white: £10 each or £15 for the pair.
If anyone wants the shell (3 door shell) it's sitting on my friends drive so it needs to be gone by this weekend latest. The damage is confined to the nearside rear quarter panel and in my opinion it could be beaten straight. The front chassis legs and sills don't look to be affected. Windscreen is still in it but I managed to crack it near the bottom by dropping a wrench on it Offers?
Any other bits you want/need just ask and I will see if I have it.
I also have about 55 litres of standard pump diesel in 20l jerry cans (you will need to bring your own cans or arrive with an empty tank lol): offers (per l or for the lot)?
Oily/exterior bits:
Interior bits:
