Threads: 37
0
Given 0 thank(s) in 0 post(s)
got some fli 4.5" (i think) i want to stick in the door. had a look at the standard ones yesterday and there is that yellow plug into the standard speaker. how do i swap it for my flis? cut the yellow plug off then attach the wires?
on the flis its just a metal bracket shaped like a B - 2 small holes that wire just wraps around.
also the same for speakers on the parcel shelf?
Threads: 151
14
Car Model/Spec: 306 D-turbo
You can pull the yellow connector apart iirc and inside there are spade connectors that will pull out with a bit of a tug, but i usually just cut the plug off and wrap it round the terminal on the speaker works fine
Team Doesn't own a 306
Threads: 117
21
Car Model/Spec: needs bwarrrp.
Given 1 thank(s) in 1 post(s)
1... 4.5" wont fit. iirc its 6.25".
2.... cut blocks off and get some spade connectors.
Threads: 37
0
Might b 6.5 I'll have check lol. Thanks guys
Threads: 37
0
too small =[ anyone recommend some good speakers that are a straight swap?
Threads: 37
0
So sound nice at high levels? Might have to get some
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
tbh its easy enough to get a sub and amp package and run the cables
