slight misfire gti 6
Had a busy first week of ownership. Got a full service including cambelt and water pump, new fuel oil and air filters, new oil, coolant and brakefluid, replaced the thermostat and spark plugs. Ive cleaned the icv and looked for air leaks but no joy. It does it at idle, have to be looking for it but its there. And it does it holing constant engine speed you can feel it misfire every few seconds or so. My code reader wont communicate. Any help would be great.
Coil Packs?
See if someone can lend you a known good set before you go out and but new ones.
Havent got anyone local with a gti 6 and been quoted £50 each. What code reader would work on a s plate? Surely it would still store a code without pulling up the eml?
Not always. Look on eBay. The coil packs turn up cheap on there.
I can do you 4 for £50 posted, could put the history in with the package as well.
[Image: 704e7db1.jpg]
Ok something wierd happened tonight. Someones been at the electrics around the ignition barrel and made a right mess. The solder on the starter motor trigger wire had fell apart inside the electrical tape. Managed to get it going again though but got to sort that in the morning. thanks for the offer bud tbh id much rather get a new coil purely because its electrical and post people arent exactly careful at the best of times
Problem solved. Was the lambda sensor. Got it plugged in with pug planet earlier there were 2 faults saying lambda malfuction it wasnt working at all
  Misfire nile306gti6 4 7,409 16-09-2018, 05:56 PM
Last Post: Mighty306
  Poor throttle response, misfire fixed! bilboaustin 17 12,351 06-12-2016, 10:37 AM
Last Post: bilboaustin
  Eml light and misfire russ.gibbo76 2 3,168 25-10-2014, 09:42 AM
Last Post: russ.gibbo76
