upper engine mount querie
Hey all just wondering about a mod. I see its pretty common for people to shim out the top rubbers on the upper left hand engine mount. My quaetion is what have you guys used? And if any, are there any negative consequenses to shimming it virtually solid?
Cambelt is being done later today so just thought id get as much info on it as i can. Thanks
Look in my project thread my engine mount cradle has cracked. I am going to weld in 2 metal shims to stop the movement and hopefully prevent it from cracking again in the future after it is repaired Big Grin
also negatives would be excess vibrations especialy if you fit a solid lower engine mount Smile
Dum Dums cabby has group n mounts and was shimmed, was much movement over standard. Although I did only test at idle lol
I have bakerbm mounts and i get vibrations. The shims will stop alot of movement and stiffen the top mount up alot Smile
Iv shimmed my group N mount. I used a bit of quarry convaier belt. Thick hard rubber
I was going to use the sole of an old boot haha. So nothing adverse about using it like that long term?
It is better for the threaded mount im the long term.
Nice one cheers Smile
This is what's gonna be done to the Rallye at some point soon, the sides have been pushed out far too much that i need a 10mm plate welded in! Sad
Black mask Service
I just used ally strip bolted in at the top.
(07-04-2013, 06:53 AM)Dum-Dum Wrote: I just used ally strip bolted in at the top.
I was also wondering about bolting such a thing in.. Undecided
Black mask Service
My engine mount is clicking when i let off the power and when the engine is started,Is this quite a common problem on these? Engine is the 1.8 16v
(21-04-2013, 05:54 PM)Jimmy306 Wrote: My engine mount is clicking when i let off the power and when the engine is started,Is this quite a common problem on these? Engine is the 1.8 16v
Sounds to me like the cradle that the mount bolts into has broken. Will need to be welded but its a small job for any good welders Smile
Thanks. Is it just steel then? Not cast?
I believe its just steel. It you take the top mount bracket off (jack under the engine to hold it up!), you can knock the top mount out (its just a standard thread. Just use a chisel and hammer to knock it round) then take it out and see if its cracked. If so, you need a plate welding in.
Brill. Thanks for your help! Didnt think the 1.8 had the power to do that lol
  Top engine mount Mighty306 6 5,727 12-10-2017, 03:24 PM
Last Post: cully
  Bottom engine mount fork bush DeeTurbo 5 3,369 08-07-2016, 10:24 PM
Last Post: Jonny81191
  Lower engine mount Niall 12 5,382 22-10-2014, 10:14 PM
Last Post: miles
