09-07-2012, 05:24 PM
Would it be possible to have the 5th gear from an HDI box in an XUD box? I don't have a spare one to poke around otherwise I would.
Ta
Ta
Gearbox gear change?
Ta
09-07-2012, 08:32 PM
just fit a HDI box
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
09-07-2012, 08:46 PM
(This post was last modified: 09-07-2012, 08:46 PM by 4WayDiablo.)
Hdi box has longer ratios so doesn't keep you on boost so much though
10-07-2012, 08:16 AM
Which is why I want an xud box with hdi 5th. I want an xud box for when I'm going through the gears but then a lower rpm when at a steady speed.
HDI and DT box are the same bar the final drive giving the longer ratios throughout the box.
And FYI the 6 box has a longer final drive than both the HDI and DT IIRC, if not its not much shorter as the hdi and the 6 are around the 3.8 region IIRC.
11-07-2012, 08:22 PM
(11-07-2012, 08:08 PM)Chris Wrote: HDI and DT box are the same bar the final drive giving the longer ratios throughout the box. Beat me to it. The 205 DTURBO box, 306 dt and HDI have the same gears just a different final drive. If you want short is gears get a '6 box and some 20" rims Troll out.
Stage 2 XUD Sedan
gearbox change | snooker147 | 3 | 1,542 |
29-03-2013, 06:12 PM Last Post: Danny2009 |
No turnover(gearbox change) | pugtk | 2 | 1,272 |
21-02-2013, 10:25 PM Last Post: pugtk |
Clutch and/or Gearbox change 205 XUD | silverzx | 8 | 5,139 |
16-02-2013, 07:21 PM Last Post: silverzx |
