Threads: 36
2
Orite lads,
What kind of boost are you lot generating through the gears with a de-wastegated, T2 bosch?
I'm hitting about 24 ish psi in 1st,
26psi in 2nd,
and about 28psi in 3rd using veg oil (+1/2 peak psi with diesel).
Not had a chance to check peak in 5th as i've only just tweaked about more today but previous peak was 28psi in 5th. Would prefer the wastegate on, but i broke the fkin plastic diaphragm nipple... so i can't obviously overfuel to get a constant boost level through the gears.
Threads: 171
46
Given 1 thank(s) in 1 post(s)
mine can push to 34psi in 4th gear, dont usually look at it in other gears, 5th is pretty much the same
Threads: 171
46
other way round mate, 9mm are not as bad as people make out to be, its the turbo that holds it back to a decent power
Threads: 36
2
I have a mint k14 from a Xantia lying around, but i'm certain the downpipe looks a different angle to a 306 one?? Any ideas?
And the fitment of the t2 downpipe looks different (the part that attatches to the exhaust housing) so i can't just swap it over. Freezing cold garage it is lads =((
Tbf though, i have been commuting for hours without a working heater matrix so i'm getting used to it which is just not right!!?
Hah, yeaaah i know - created epic heatsoak when pressing on. Still, Dturb 1 - Insignia 0 =D (even though it was for all of 30 secs with the new tweaked settings =p)
Threads: 171
46
Dunno about the downpipey bit. I know the bit your on about the 90 bend
And yeah ive had no heating in my car since ive owned it about 8 months now
Threads: 36
2
I payed £10 for a 150w ceramic heater off ebay, it's utter SHIIT! Does jack all. Might cave in and actually rip the dash out. Getting ridiculously cold now man.
Threads: 3
Car Model/Spec: 205 1.8 TD Mardi Gras
If you want more revs on veggie oil then I would think that a 10mm head plus bigger delievery valves and bigger nozzles would help.
