30-06-2012, 08:01 AM
as titled. x2 please. pm me with details.
Wanted: 20mm hubcentric spacers.
30-06-2012, 08:35 AM
Peugeot to Peugeot? If not I have Peugeot to after market
![]() TEAM CONROD SHITTING RALLYE!
30-06-2012, 08:38 AM
for my after market ones matt. foxy jim sold me a naff set and one of my wheels is only held on with 3 bolts so need to get this sorted. got spigot rings.
30-06-2012, 08:43 AM
What's the centre bore measurement? My spacers have the Peugeot bore on inside and the after market wheel size on the outside. Iirc I'll take a look when I can be bothered to actually move haha
30-06-2012, 08:52 AM
dont know mate. all i know is the wheels needed spigot rings to fit the spaceres. how do i find out and how much do you want for them if they are the right ones buddy. posted.
30-06-2012, 09:30 AM
Posted do em for £20?
It sounds like they are the standard after market size. Checked mine and you need spigot rings on the inside of the spacer, so the inner of the spacer will fit onto the normal pug hub with a ring, and the outer will slot into the wheel with no rings. Oh and they are hubcentric ![]() TEAM CONROD SHITTING RALLYE!
30-06-2012, 09:42 AM
Threads? These are ones that you use extended bolts on
30-06-2012, 01:19 PM
ahhhr, with ya. are these ok. heard bad things about em. i got the bolt to the hub then bolt to the spacer kind. witch one is best.
30-06-2012, 01:38 PM
when i bought the wheels the lad said hes HAD THE THREADS CLEANED but the bolt had a slight bit of play in it. after putting then on my car for the first time i was never happy with them and had no confidence. after i did my wheels and put them back on (with the spacers) on of the bolts just span. i could get them re threaded but wouldnt i need bigger (wider) bolts?
30-06-2012, 03:02 PM
I have same as mate Kingy but 15mm mine are stud conversions as well. At first I was very nervous about them but after a few weeks and checking them for a 4th time I've decided they're safe
30-06-2012, 03:37 PM
It's a shame I know where thereS a nice set of Aidels. As I need some money for my computer build but I know soon as I get I'll smash one of mine on a pot hole.
01-07-2012, 08:08 PM
Get it helicoiled. Keeps the same thread size them
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead |
| Wanted: 15/20mm hubcentric spacers. | Chris_90 | 0 | 1,661 |
13-05-2017, 12:02 PM Last Post: Chris_90 |
| Hubcentric wheel spacers | 306pc | 0 | 1,591 |
29-02-2016, 11:06 PM Last Post: 306pc |
| WANTED 10mm hubcentric spacers | bashbarnard | 2 | 2,129 |
13-02-2015, 07:36 PM Last Post: bashbarnard |
