Threads: 129
11
Given 0 thank(s) in 0 post(s)
I started tidying up the garage when I got home from work today after watching Darrens latest video's it made me think of how much of a state mine is. But I ended up stripping down my old engine and making even more of a mess.
Started by removing the head to find the headgasket to be the wrong one by the looks of it. The water channels from the block to head looked very restricted by the gasket with holes about 3mm round...
Apart from that the bores, valves and pistons looked in surprisingly good nick for a 176k engine.
Then removed the sump and started taking everything out. I've got to the point where I just need to remove the bottom pulley to take the crank out but everythings unbolted apart from that which is annoying as the pulley bolts f-ing tight!
Half tempted to rebuild it and fit the HDI rods I bought of Dave and maybe some ARP studs. Either that or get another '9 and fit them to that.
I would upload the pick but I havnt got the iphone cable sorry
Stage 2 XUD Sedan
Threads: 29
18
Car Model/Spec: mx5 mk1 1.8
27-06-2012, 08:10 PM
(This post was last modified: 27-06-2012, 08:11 PM by MissTap_GTI6.)
(27-06-2012, 08:07 PM)strictly_derv Wrote: I would upload the pick but I havnt got the iphone cable sorry
I didn't think that one through, did I...
Threads: 129
11
NO. Well I got given another but forgot it!
Stage 2 XUD Sedan
Threads: 374
38
Car Model/Spec: GTI 6
DO IT!!
Im more than game to come over and chip in if you need a hand! OR, buy a new engine, and rebuild one, HDi rods, etc.....??
Threads: 90
54
Gasket is meant to have little holes like thats, its to make sure water flows up around the block / head equally, otherwise it would all go up the easiest route / create hotspots etc
Threads: 129
11
27-06-2012, 09:21 PM
(This post was last modified: 27-06-2012, 09:22 PM by strictly_perv.)
(27-06-2012, 08:58 PM)ginge191 Wrote: DO IT!!
That would be good. Or come help with the paddle clutch fitting when it comes (will be buying it tomorrow )
(27-06-2012, 09:08 PM)darrenjlobb Wrote: Gasket is meant to have little holes like thats, its to make sure water flows up around the block / head equally, otherwise it would all go up the easiest route / create hotspots etc
Ahh makes sense now.
Does anyone know what makes the CC difference's between the 2 engines? Bored out or shorter rods?
Stage 2 XUD Sedan
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
Should be the bore, as the 90 hdi uses the xu7 and the 110 xu9 cranks
Threads: 36
2
The xud7 is 80mm bore vs 83mm xud9 iirc. Same throw
Threads: 90
54
What they said^^
The XUD7 has lovely thick cylinder walls for ra*e.99 b00st tho Ive got an XUD7T block sat in my shed rusting out, might use it one day!
Threads: 129
11
Should help reduce chances of a flying rod then
Stage 2 XUD Sedan
Threads: 90
54
Hm, probs wont help that, but should help once you have manned up and forged it, and throwing 100psi down the intake
Threads: 41
12
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
I would get an xud9 personally... you will just make more power with it ...
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
If you do rebuild it with HDI rods please take lots of pictures incase I get stuck! I am about to start mine..
