22-06-2012, 05:49 PM
Got a bad grinding kind of noise from the car when driving, Bad vibrations tho the wheel and pedals. I removed the wheel and apart from the brakes binding(all 4!!!) when i run it up in gears the noise is horrendous and seems to be coming from the inner bearing that runs thought the lower engine mount??
No play in the wheel so i am sure the wheel bearing is not the issue and the driveshaft itself. Cars done 170k and i can only assume its the original shaft plus i just drove from scotland to Leeds nonstop at some excessive speeds.
Anyone just confirm driveshaft?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Blaze 1.6 Dead
