Threads: 4
I suffer alot of heatsoak in 4th and 5th gear in my td04 9mm. Looking a fmic kit but dont want to be buying bits i really dont need. The car is a ph2 if this helps and i will be looking to upgrade to 11mm pump in the near future.
Any links or help appreciated.
81
Not sure there is any difference between phase 1 and 2 that makes a difference between what stuff you need to get. Presume youre already running a bosch. There isnt a ready to bolt on kit as such unless you can find one second hand. All the parts are sourced individually and mostly from ebay. Most people go for a 2.25" setup. You dont need a massive intercooler to do the job. Often OEM ones from other cars will be super cheap.
