19-06-2012, 10:18 AM
Im looking for a passenger side drive shaft for my phase 1 dturbo, is there differences in the other phases/models? Thanks
306 Driveshafts
19-06-2012, 11:02 AM
I need an answer as fast as possible as i want to buy one today
Sorry for the quick bump!
19-06-2012, 11:04 AM
should be the same as all XU engined cars. (1.8, 2.0 xsi, 2.0 gti, 1.9d, 1.9DT)
19-06-2012, 11:07 AM
Rang a scrappy and he told me there is a different amount of splines between phase one and phase 2? Is this true?
19-06-2012, 11:13 AM
that, i couldn't tell you. but i didn't think there was as all the gearboxes are interchangeable, i think.
19-06-2012, 11:24 AM
Thats a good point actually.. You dont need to change drive shafts when putting on a hdi box so they have to be the same........ Anyone confirm this
19-06-2012, 11:25 AM
all xu are same fitment. has your car abs though?
need one of an abs car if you do iirc
could always get a lift to the scrappy, and take your old one with you. then just compare them
19-06-2012, 11:28 AM
No dont think it has abs.. Ill check now
Ill do that samass
19-06-2012, 11:29 AM
Only difference I know of is the ABS sensor ring being present or not!
(This post was last modified: 19-06-2012, 11:31 AM by sweeney1987.)
short shaft youre looking for?
id say i have one off an abs xsara here if youre stuck infact think i have a few different ones in the shed but i cant currently get in it :/
ah yeah, good point sweeny, abs! easy to check, just look for a pumpy looking thing with lots of brake lines going into it at the front of the passenger side chassis leg in the engine bay, behind the headlight
Thanks sweeney i was only up your way yesterday too for the rally
Think i have one sorted.. If i put a non abs shaft into one with abs what would happen? Just not click into place?Nope no abs
19-06-2012, 11:36 AM
my way? im not from donegal?
didnt think there was a rally in cavan :$ If you dd that id imagine the abs wouldnt work
| DW8 into 205 Driveshafts/gbox problems? | 089 | 4 | 3,911 |
27-03-2015, 07:03 PM Last Post: 89 |
| 205 Xud9 conversion - driveshafts | rd070707 | 3 | 2,560 |
20-10-2014, 01:42 AM Last Post: Sambarker |
