16-06-2012, 04:20 PM
finally got the bugger holding boost turned out to be the actuator after all must have been really screwed to get the readings i was. off the car prior to fitting it was fairly stiff and resistant but on the car its quite movable!
Any ways spec
T25 turbo - De waste gated 25-28psi depending on gear
9mm bosch pump
Ground LDA
Lda spring adjusted
Top mount cooler
single box exhaust system
0-60 (65 on the dial incase)
30-60 3rd gear full throttle
30-60 2nd-3rd gear
May not be quick as some others that are in hear but can pack a punch when cruising certainly likes to pick up well. little more tweaking then itl be on the dyno to see what it pulls. then fmic then possibly 11mm pump
Any ways spec
9mm bosch pump
Ground LDA
Lda spring adjusted
Top mount cooler
30-60 2nd-3rd gear
www.prestige-auto-care.co.uk
