how do i remove centre dash trim?
hi i would like to know how to remove the dash trim from around my sterio, blowers and heater controlls?
i have removed the piece from around the fag lighter and clock it is just how to remove the rest i'd like to know please
Unscrew the clock and the two screws at the bottom holding that section in.
Unclip all the buttons hazard light and what every else you have down there.
Pull ou the radio and unplug everything. Remove the cage that holds it in place.
Either side of the radio slot there is a bolt nut either side. Using a small spanner undo these then you can pull the main fascia off be gentle the bolts either side of te slot sometimes break.
Then the top vents. Undo the two or three screws below the vents, then pull gently and un clip them from the vent pipes behind them.
thanks that's very helpfull Smile
Glad to hear it.
can't believe im saying this already - use the search bar
there's an entire guide on it - http://306oc.co.uk/forum/thread-3108.html
thanks followed the guide all i can't do atm is take the blowers out the top i have took the torx out and it seems extremely stiff to get out i don't want to break anything
Pull pull pull. When the top comes loose you need to unclip them from the pipes behind.
will do cheers just didn't want to force it if i was missing something out cheers Smile
  Centre console dash bottom piece grrrrr Razorback_Rob 15 9,939 01-09-2014, 12:17 PM
Last Post: Razorback_Rob
  Need to remove centre console LeeroyNI 8 4,411 15-11-2013, 09:20 PM
Last Post: DeeTurbo
  How do I remove the dash Mart 9 5,304 17-01-2012, 02:41 PM
Last Post: devils_fuel
