Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
Includes everything in the photo, all connections have clips, have included some extra straight pipes and silicone bends. The fans have been modified to plug straight into existing phase2 rad. Original bumper requires NO trimming, and just requires four small 4mm holes drilling in the slam panel and bottom shelf, brackets and bolts included.
Xantia mani
Slimline fan+plug
Intercooler
Pipes + clips
Mounting brackets
Obviously dosent look as nice as when I first put it on 2 years ago, but weather and all that, dosent affect performance one bit, so if you're like me and just care about HP alone, buy this! Does look good through the front of the grill anyway.
On car:
No bumper trimming required:
Through grill:
FCS Pickup.
Dave
Threads: 23
Car Model/Spec: Blaze XUD ph 2.5
Where you from?
Blaze XUD Dturbo
Soon To Be Stage 2..
Threads: 87
48
tempted, wouldn't fit over my phase 1 nissans rad though without some messing about. . . . . :think:
Car Model/Spec: 306 D Turbo
Did you have to modify the slam panel at all to get the pipes over the rad like that?
Great price by the way with the xantia mani as well!
Threads: 41
Cheers, its priced to sell so I can get rid at fcs!
Slam panel is stock. Only thing that needs to be done is replace fans with slimline, which I've made all plug and play anyway.
Threads: 41
Louis123 Wrote:Where you from?
Grantham/Northampton
Threads: 23
Aahh what a bummer to far away!
Blaze XUD Dturbo
Threads: 41
Derbyshire, thats like half hour from me and donningtons even closer still!
81
would it be possible to have a guide of how to wire up the fans?
Threads: 41
They have the fan control unit with them, just plug them straight into the rad.
Threads: 110
20
I'm half tempted. Do you know if it would fit a mark 1 very well?
Threads: 41
In all honesty it would probably fit the phase1 better due to the header tank not being there.
Threads: 23
Just put Northampton In on sat nav and it's 3hours away lol I'm near the Tameside side of derbsyhire
Blaze XUD Dturbo
Threads: 87
48
Dave Wrote:In all honesty it would probably fit the phase1 better due to the header tank not being there. looks like it'd block the filler cap for the radiator tbh mate . . . . this is what's stopping me counting up my change jar . .
Threads: 23
Pm'd!
Blaze XUD Dturbo
Threads: 30
Car Model/Spec: Bianca 6 + 205 1.9 Gti
Threads: 41
Threads: 41
Threads: 374
38
Car Model/Spec: GTI 6
Phew... This is a snap and I can't spend more on te dturbo.
