twin fans wont work
twin fans wont work
Hey new to this and looking for sum advice on my peugeot 306 1.4 meridian has ne1 got ne ideas y my car overheats wen it crawling in traffic it normally runs at about 80 but wen crawling its nearly in the red and wen i turn air con on my fans kik in sumtimes but not always has ne1 got ne solutions b4 i go spendin money which i may not need thanks
m8 as i sed on fb i reckon iz a prob wid da loom dat gos in2 the fanz.
fan switch in the thermostat housing. or the coolant needs bleeding.
Where bouts is the thermostat housing
ehhhmmmm on the 1.4, not 100% sure, but at a guess, if you follow the pipe that comes from the top right hand side of the rad (passenger side) to where it goes into the block, its normally there. should have a couple of wires going to plugs on the top
SRowell Wrote:m8 as i sed on fb i reckon iz a prob wid da loom dat gos in2 the fanz.
Whhhoooooaaaaa what happened? Where did you understanding for the English language go?!
  twin fans operation Magenta Sunset 3 3,188 07-08-2016, 02:22 PM
Last Post: P-Courty
  indicators wont work :/ hilly5672 2 3,076 24-05-2016, 10:48 PM
Last Post: hilly5672
  Fans...HDi fans... HDi slimline fans... wiring.. toseland 3 3,538 07-09-2015, 09:52 AM
Last Post: cully
