piston protrusion
how many mm do the pistons in an xud protrude by? Accuracy is key here..
Quick answer appreciated as, quite ironically, i have my grinder out ready...ooh err
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
For future searches.
https://docs.google.com/viewer?a=v&q=ca ... 0Tn699oSoA
Is it not in the guide that I posted in the XUD section where you just posted this?? Tongue
like this one - <!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=12&t=3662" onclick="window.open(this.href);return false;">viewtopic.php?f=12&t=3662</a><!-- l -->
Team Orange Engine Bay
Yeah i could of sworn i read it in there, ended up finding it - page 3, 56 or something midway through. Found above link first, easier to find :p
Going to practice grinding on a scrap renault block/pistons before taking to the xud block. Shame it protrudes less than a 1mm though :/ which is what i want to lopp off ideally..!
IIRC each block needs measuring individually due to differences in manufacture and the possibility its previously been skimmed.
Easy to do, pop 2 pistons at TDC, run a straight edge between them and stuff feeler blades between the straight edge and the block face.
  Piston Rings Hobo Ash 5 5,423 15-09-2017, 07:59 AM
Last Post: Dave
  Max Piston Protrusion / Notches Cford 2 3,688 03-08-2017, 05:52 AM
Last Post: Cford
  Piston Ring Modification JTaylor2005 10 6,675 08-09-2016, 01:59 PM
Last Post: zx_volcane
