Heater Fan Full Power (Auto panel)
Hello everyone,
I haven't driven my car for 2 years and it was waiting for paint, then the work was done and I took my car back.
But the heater fan works non-stop.
First, I looked at the fan relay, it was clean, but I still bought a new green relay, I installed a new fuse, then I bought a 6441A1 (resistor unit), but it still continues to have full power.
Where should I look?
Does it affect the interior temperature sensor (6445AJ)?
the panel lights are working.
A/C and interior cover open and close are working
I removed the brown socket going to the fan and measured it with a multimeter, when I change the fan speed, the volts change, when it is at full speed it is 7.45 v, when it is off (I know it is not fully off ) it is 11.36 v.
I think this means the panel's signals are correct.
But I don't understand why the fan speed doesn't change. I have 2 fan modules, 1 is magnet, Marelli and the other is Sagem, but nothing has changed in both of them, they are still full power.
I just connected the module without connecting the fan and measured the black and red cables that will go to the district fan with a multimeter.
When I changed the fan speed setting on the panel, the V at the module output did not change.
I need some advice where I should look.
Note: The dark brown cable with its empty counterpart at the very end of the panel socket seems to have melted a bit.
Today I removed the tiny fan on the ceiling and found the socket disconnected, I plugged it back but it still didn't work.
The only thing I haven't changed now is the fan motor itself. Could 2 modules be defective?
Even though no one knows anything, I solved it.
I don't understand how it happened, but I changed the places of the thick black and thick red cable in the 3-wire socket going into the FAN motor and now I can control it. I looked at the first socket of the heater wiring harness, it should be there, but I didn't understand how this could happen.
That's very odd.  Glad you have it working again though.
  heater control panel chris.rawe 10 6,853 09-02-2013, 02:31 PM
Last Post: chris.rawe
  Heater control panel wanted - north east brettw1 8 5,472 12-11-2012, 03:08 PM
Last Post: Smiley69
  niall ! your heater panel cully 21 11,857 15-02-2012, 06:07 PM
Last Post: Niall
