Rear quarter cards
How do i take off the interior panels out of the back of my car? And centre pillar trim?Is it just clippped on? Its a 3 door Thanks
For the centre pillar, remove the seals around the door and window. Grab the height adjuster for the belt and pull hard till it comes off. Under there is a tiny torx. Remove it and the plastic cover. Now remove the 17mm bolt holding the belt in place and pull the trim off.
Now for the card. Remove the t20 that was behind the pillar trim. Grab the pocket and lift it up and the cover will come off. Remove the t20 behind here. Now, remove the 2 t20s in the boot. These are easy to see. Remove the 17mm bolt for the bottom of the rear seat belt.
Take the rear pillar cover off. There is 2 t20 bolts holding this in and the boot and window seal. Remove the screws and pull. Now, the door card is just clipped in so pull gently and slide out. Job done!
Thanks very much buddy i didnt know about pulling off the height adjuster so thanks for that! Ill get to it tommorow
Yeah grab the knob and give it a good tug till it comes off in your face like mine did.
I'm talking about my car by the way....I know what you were thinking!!
This is my first time at this kind of thing ill take it gently ha did you paint any of the b pillar black while you had it off?
Mine are already black mate
  Rear quarter panels PugLee 0 2,014 19-04-2018, 12:39 PM
Last Post: PugLee
  3dr rear quarter window willJspears 4 3,442 23-10-2014, 08:40 PM
Last Post: willJspears
  Rear quarter window 5 door adamm306 8 5,100 19-08-2013, 03:34 PM
Last Post: adamm306
