Possible head gasket issues?
Hey all, I've got a DW8 powered 306 which I'm having some strange issues with - I bought it off a chap (who was on here I think at one point...) knowing that the car had a suspected head gasket problem, now it would use water quite slowly and wasn't smoky from the exhaust nor was there any mayo from the oil cap, what I did find when pressure testing was a split in the hose going to the back (heater matrix, possibly?) of the bulk head, I cut this and repaired it and a pressure test was carried out again and it was as it should be - left for some time on idle it got to good temperature and didn't use fluids.
a couple of days later we drove it 40 miles up the road and got stuck in some traffic, the car perhaps raised the gauge to between 95-100c and the fan kicked in bringing it back down to around 80c it had used some coolant, but certainly not all of it, just enough to notice a difference though.
I sent it off to another garage who did a pressure and chemical test on it, which came back fine - one of the rear hoses was hard which my mechanic suspected the head has gone but this actually sorted itself out, which led him to believe there was a block somewhere which had perhaps shifted. I had the timing belt and water pump done on it.
Taking it out the other day, I gave it some welly around town where the roads were clear and it stayed at about 75c consistently ( 20-25 minute drive).
We have found that the coolant bottle seems to stay at around a quarter of fluid each time we've checked it / filled it up....
Is it new head time? Or is there something else going on?
Thanks in advance.
These can be quite difficult for getting all of the air outside the cooling system. As far as I know when a head gasket goes on an XUD (or DW8 for the matter) its quite dramatic and I don't believe it has repaired itself by any chance.
Also, the electric earth issues can cause all kinds of a erroneous temp readings on the gauge. Just to be sure, connect additional ground wire from the negative terminal of the battery to position that is close to the temp sensor for the gauge. At least you will know the temp indicated is not influenced by the voltage drops on the earth system.
Thanks given by: forbeslongden
From a little more time with the car, what I have found is that if you top the coolant all the way to the maximum indicator, it'll use/lose the fluid down to a quarter of the expansion tank, it'll stay here without losing any more - I assume this is pressure in the system?
Tank sitting at a quarter full when cold sounds normal to me.
install norton antivirus to protect your computer from any virus attacks. click here download norton have product key for more details .
Get started with Office product by downloading and installing it. Type the product key at microsoft office 365 account
Webroot Mobile Security is a multi client permit enabling you to utilize your permit on up to 3 gadgets. webroot download with key code On the off chance that you are utilizing the most extreme number of gadgets you should uninstall from the old gadget preceding introducing on the new gadget.
Install mcafee product without any hassle. We provide best installation service mcafee.com/activate click here enter mcafee activation code for more details.
The Roku Channel is your home for nothing and premium , anyplace you go. link code roku tv Stream many hit films, famous shows, all day, every day live news, and more for nothing. Effectively include and oversee Premium Subscriptions like Showtime, Starz, and Epix with one login, one bill, and one spot to stream them all.
Hulu is outstanding amongst other gushing administrations that straightforwardness access to content on various sorts of gadgets. hulu sign in You can stream crosswise over PCs, cell phones and gaming reassures. Be that as it may, before getting a charge out of this administration you should buy in to the administration and enact your Hulu account.
Roku provides the simplest way to stream entertainment to your TV. roku link support On your terms. With thousands of available channels to choose from.
Hulu is one of the best streaming services that ease access to content on different types of devices. hulu sign in You can stream across computers, mobile devices and gaming consoles. However, before enjoying this service you will need to subscribe to the service and activate your Hulu account.
download microsoft office 2016 windows, microsoft office 2016 windows, my office account 365 microsoft office 2016 windows download free
After you buy Norton Antivirus visit norton setup, sign in to norton account by then enter norton thing for Norton Setup norton install with product key or Install Norton Antivirus
mcafee antivirus is broadly utilized aantivirus identifies and kill PC infection, the mail worms,the trojan programs,and additionally enables your framework to free of infection and other malware is a significant every day challenge. for more subtleties visit: install mcafee with activation code today.
Install the best antivirus in your computer with the best support team. we are providing webroot installation - webroot download with key code
Do you want to set up hulu antivirus in your computer then click here hulu login for more details.
Roku is a streaming device, which is a reasonable roku setup and other Set-up Box. Roku is a bundle of amusement, roku link to enter my code where client can stream for boundless motion appears, web arrangement, news, animation and a lot more projects.
enter avg retail activation code to install and activate your avg antivirus software instantly.to download avg visit : avg registration key
download microsoft office 2016 windows, microsoft office 2016 windows, microsoft office 2016 windows download free office setup and enter product key
enter Roku activation code and enact your roku device. Contact for Support if confronting any issue. Activation Roku Code Link Get help with arrangement and investigating, discover answers to account and charging questions, and figure out how to utilize your Roku gadget.
office setup is the best software which is widely used in globe .It is a powerful service that helps you unleash your best ideas , get things done, and stay connected on the go.for more details visit: office setup and enter product key
are you interested in using office 365 products here we are providing full support to make your computer working with office. my office account 365 you dont need to work on anything as we will help you to setup your office product.
Fix printer problems in Windows 10. When you connect a printer to your PC or add a new printer to your home network, you can usually start printing right away. Windows supports most printers, Fix Printer Offline Problem in Windows 10 and you probably won't have to go out of your way to install special printer software.
McAfee activate thing key your private endeavor's PCs against diseases and distinctive harmful tasks. install mcafee with activation code All together to prevent the unlawful appointment of its item, all must be authorized using a stand-out key.
Norton Security Standard, Norton Security Deluxe and Norton Security Premium are no longer available as a trial .norton internet security We have refreshed our insurance and offer NEW Norton 360 plans, with additional features, like Secure VPN, PC SafeCam, PC Cloud Backup. introduce norton setup in your pc.
A technical service is a dynamic grouping of configuration product , mfsetup based on some common criteria. Technical Services team which offers support to customers for solving their technical needs.
Technical support or mcactivate refers to a range of services by which enterprises provide assistance to users of technology products such as mobile phones.
Antivirus is the need of computers that makes them virus free and we are going to give you full support to get the best antivirus installed in your computers and laptops. Download norton antivirus package with us - norton install with product key
visit micropds Information Technology Technicians assist employees of organizations by helping them install and configure system software and hardware.
download the security product, and give you the best protection against online threats that won't interrupt your work by webroot secureanywhere download with key code
Install mcafee antivirus in your computer with high class professionals and best tech team. Just ring us and we are ready to assist you till the last minute of installation - enter mcafee key code
Activate mcafee antivirus with the highly professional tech team and get rid of antivirus from computer. click here for more details : install mcafee
Norton Antivirus is one the most widely used norton install with product key and trusted anti-virus software in the world managing to protect users of all knowledge levels and all hardware configurations against malicious software threat that are targeting Windows-powered services and privacy of their users. It efficiently detects and removes viruses, worms, Trojans and countless other types of threats automatically, without intruding on your …
Do you want to install webroot in your computer?? visit webroot download with key code here we are proving you best support to get it installed in your computer.
Avg is a well- known name in the field of virus protection. The reason for which this name is common among all end users is its free antivirus and malware protection. It not only sounds download and install avg ultimate free but it provides a lot more with no money. It scans for virus and malware.
Finding the Roku link code location is easy; Roku Activation Code it is displayed on the TV screen during the activation process. Below is a look at the step-by-step process of acquiring the code: Using the instructions manual, make all the necessary connections for the Roku device and power it on.
Activate roku link to enter my code, go to enter Roku com link code displayed on Roku TV. My roku com link not working use new Roku code
this is simplest way to stream entertainment to your TV. On your terms. With thousands of available channels to choose from link code roku tv for more detils.
enter avg retail activation code to install and activate your avg antivirus software instantly.to download avg visit : install avg with license number
The Roku Channel is your home for nothing and premium , anyplace you go. roku link support Stream many hit films, famous shows, all day, every day live news, and more for nothing. Effectively include and oversee Premium Subscriptions like Showtime, Starz, and Epix with one login, one bill, and one spot to stream them all.
Do you want to set up hulu antivirus in your computer then click here activate hulu for more details.
Antivirus is the need of computers that makes them virus free and we are going to give you full support to get the best antivirus installed in your computers and laptops. Download norton antivirus package with us - norton security
Make a account and complete things, have a ton of fun, and keep in contact. A free account gives you simple access to everything advanced. office setup and enter product key Sign in with our site to keep everything that you need in a state of harmony on your gadget. Get free access to Office Online, Outlook, Skype, OneNote, OneDrive and then some. Have a ton of fun.
McAfee security programming offers a standout amongst the best malware insurance among the various security suites in the worldwide market. enter mcafee key code As per the most recent reports, there has been noteworthy development in digital assaults in the course of recent years.
It is all time best protective antivirus and anti-spyware .It is real time protection technology and it is safer , faster and more complete than ever before.if want to install it then visit our site: install webroot antivirus with key code
We provide technical support for your installation through in-depth knowledge of products and solutions in your installation. getsofti Our experienced technical service network is ready to help you with an extensive service and solution array.
Finding the Roku link code location is easy; it is displayed on the TV screen during the activation process. Enter Roku.com Link Code to Activate Roku Below is a look at the step-by-step process of acquiring the code: Using the instructions manual, make all the necessary connections for the Roku device and power it on.
install norton antivirus to protect your computer from any virus attacks click here : norton security for other details
Technical support refers to a range services companies provide to their customers for products such as software, malware bytes support mobile phones, printers, and other electronic, mechanical or electromechanical products.
webroot cyber security is a ultimate internet security suite for complete protection against today's diverse range of threat on windows. key features are 100% secure secure shopping, 1 click virus scanning, malicious website filtering, unblock antivirus.if you want to install it then visit our site:webroot activation support
Get your Office Setup Installed with the help of the best help team. office activation support You may install the complete office 365 package without any complicated work.
Norton Security Standard, Norton Security Deluxe and Norton Security Premium are no longer available as a trial . We have refreshed our insurance and offer NEW Norton 360 plans, with additional features, like Secure VPN, PC SafeCam, PC Cloud Backup. introduce norton activation support in your pc.
Activate mcafee antivirus with the highly professional tech team and get rid of antivirus from computer mcafee activation support
Avg is a well- known name in the field of virus protection. avg activation support The reason for which this name is common among all end users is its free antivirus and malware protection.It not only sounds avg.com/retail free but it provides a lot more with no money. It scans for virus and malware.
mcafee antivirus is widely used aantivirus helps to detect and neutralize computer virus, the mail worms,the trojan programs,and also helps your system free of virus and other malware is quite a daily challenge. for more details visit: mcafee activate with activation code
Norton Antivirus is one the most widely used and trusted anti-virus software in the world managing to protect users of all knowledge levels and all hardware configurations against malicious software threat that are targeting Windows-powered services and privacy of their users. It efficiently detects and removes viruses, worms, norton com setup with product keyTrojans and countless other types of threats automatically, without intruding on your …
  Head gasket (again!) Pughawk 1 575 08-11-2019, 08:59 AM
Last Post: Mighty306
  Head gasket and Engine rebuilds. weka 2 867 15-07-2019, 08:46 AM
Last Post: weka
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 1,073 22-08-2016, 09:57 AM
Last Post: r3k1355
