Decat pipe for 306 S16
Hello,
I'm looking for a Decat pipe for my peugeot 306 s16 XU10J4
Thank you
not sure if it has the same manifold design as the gti6. Maybe check if the cat pipe is the same part as a GtI6 and then a gti6 decat will fit.
nope they are different lengths.
The manifold is much closer in design to the XU10J4R (16V XSi), but how close I don't know.
What I need is to fit on the manifold, because i'll be doing a custom exhaust. But I think that the Gti6 and S16 manifolds exit are a bit different, I don't really know though.
(03-10-2019, 09:22 AM)Eeyore Wrote: not sure if it has the same manifold design as the gti6. Maybe check if the cat pipe is the same part as a GtI6 and then a gti6 decat will fit.
The part number isn't the same, probably due to different lengths on the manifold.
What I really need is a stainless exhaust flange to fit the manifold
  406 FMIC inlet pipe and turbo pipe Paul_13 3 3,539 18-12-2014, 06:00 PM
Last Post: Paul_13
  Wanted: 3 inch air feed flexible pipe/alloy pipe Chris_90 17 11,422 09-11-2014, 11:20 PM
Last Post: eskimogod
  Wanted: HDI Decat pipe Arron 5 4,005 14-10-2013, 11:34 AM
Last Post: Arron
