.4 gearbox change upgrade info
Hi, has anyone with the 1.4 meridan changed the gearbox for better acceleration. And does the 106 quicksilver gearbox fit. I was told it would change the ratio and lose top end which I'm not fussed about. Or does anyone have a recommendation on which box would be an upgrade for the standard box.
Cheers Harvey
I fitted a 206 one, more for the reason that the old box was knackered. I think it's got a slightly longer third.
Don't think you'll massively improve a 1.4s acceleration with a shorter box though.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
I fitted a slightly later 1.4 one that had a lower final drive which helped somewhat - 4.54 vs the original 4.29 - but mine was a single linkage box, not the late 3 linkage, so my options were pretty limited. It was really only because the box was perfect inside versus looking at many that were half shot.
(04-03-2019, 05:16 PM)Alan_M Wrote: I fitted a 206 one, more for the reason that the old box was knackered. I think it's got a slightly longer third.
(05-03-2019, 04:59 PM)Rippthrough Wrote: I fitted a slightly later 1.4 one that had a lower final drive which helped somewhat - 4.54 vs the original 4.29 - but mine was a single linkage box, not the late 3 linkage, so my options were pretty limited. It was really only because the box was perfect inside versus looking at many that were half shot.
I think you deleted your message by mistake there Big Grin
(06-03-2019, 12:27 AM)Rippthrough Wrote: I think you deleted your message by mistake there Big Grin
... doh Smile
  Gearbox Change help!!! danarthurton 12 7,510 21-10-2014, 11:09 PM
Last Post: Piggy
