ph3 door power
Hi all,
I fancy putting some led strips on the bottom of the doors for night time stepping out.
is there likely to be a switched power supply in the door harness that only comes live when the door is opened that I could connect to?
(I don't have my Haynes handy).
Hate Housework!
I can't give you an exact answer because I don't know but surely there's a switch somewhere that tells the standard interior lights to turn on and then fade out when doors open?
1999 - Black Rallye
1999 - Silver HDi Meridian
that's what I had in mind. thanks.
Hate Housework!
(14-09-2018, 09:27 AM)Magenta Sunset Wrote: that's what I had in mind. thanks.
You'll have to figure out which wire you need but I can't see it being all that difficult, sorry I wasn't much help but good luck!
1999 - Black Rallye
ThumbsUp
Hate Housework!
Ph1+early Ph2 has door pin switches
later Ph2+Ph3 has a door closed switch in the door lock
GTI6 Info
ah-ha! most excellent information, thank you!
Hate Housework!
