High exhaust manifold pressure
Brief background:
Cars got a gt2052v vnt turbo installed with a wastegate actuator to operate the vanes either on or off. Reving the car up on stock map would cause the turbo to chatter resulting in the engine stalling.
Last night i mapped the car up to my old stage 2 160bhp power to run it in a little bit. This has caused excessive exhaust manifold pressure. When i now rev the car and cause the chatter it takes the engine out briefly onto 3 cylinders which i believe to be a valve floating open. This clears up in seconds
Tonight my intentions are to rig up a temporary emp gauge and adjust the vnt top screw to bleed the pressure off tye manifold to a safe level.
My question is whats considered healthy emp and a dangerous level of emp?
Sent from my BLA-L09 using Tapatalk
Still Living For The 306  Rofl
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Maybe a stupid question, but why not just put a proper map on it? It will never run properly without the vnt control mapped in and there are a few mappers who can do it properly these days...
  Exhaust Manifold. Jonny81191 80 26,440 23-10-2015, 04:35 PM
Last Post: JTaylor2005
  306 hdi high pressure pump Dougieboy1 18 2,905 08-02-2015, 02:49 PM
Last Post: Poodle
  High pressure fuel pipe Mr_Nuclear 8 1,828 03-01-2015, 11:11 PM
Last Post: Mr_Nuclear
