02-08-2018, 08:50 PM
Hi, would et29 offset (7x16rim) with 10mm spacers cause rubbing issues on the inner arch or suspension? or would i need a larger spacer?
thanks
thanks
sorry....another offset question
thanks
03-08-2018, 09:14 AM
Use willtheyfit.com to visually see the difference between your existing setup and new one.
03-08-2018, 09:26 AM
Cyclones are ET18 aren't they? So there'll only be 1mm difference with your setup...
03-08-2018, 09:39 AM
(03-08-2018, 09:26 AM)Toms306 Wrote: Cyclones are ET18 aren't they? So there'll only be 1mm difference with your setup... Except cyclones are 6J aren't they? So it'll probably only be 1mm closer to strut tower but 1" closer to the arch (if i'm getting this the right way round)
03-08-2018, 06:08 PM
thanks for that link Midnightclub, according to the site it will sit closer to the inner arch but with a spacer it should be fine, if not very close.
Wheels offset | arooscroocked | 1 | 1,325 |
24-07-2018, 05:56 PM Last Post: Poodle |
borbet offset | tysonbully2k12 | 1 | 1,017 |
26-09-2014, 06:41 PM Last Post: Toms306 |
offset | willJspears | 16 | 2,819 |
11-01-2014, 12:39 AM Last Post: Kezzieboy |
