Transit connect losing coolant
Evening all,
Have recently bought a 2014 1.5 transit connect. The garage selling it did the cam belt and pump on it before sale as it was due. The day after I collected it it briefly overheated. When checking, it seemed to have a massive air lock so I put it down to a rushed bleed. It’s now started over heating briefely again and is losing coolant. Thankfully it’s not drinking It because it’s leaking on the drivers wheel.
The Issue is that on the bottom of the tank is a small nipple which seems to be releasing the coolant periodically obviously this isn’t right but why is it happening. Do we think faulty valve or some sort of excess pressure causing it to leak?
The garage have agreed to take it back (it’s inder warranty) but I’m so busy at the moment I can’t be without a van so if it’s something I can easily sort myself I will do!
Take it back it’s inder warranty ask for a replacment while its in for repair
GTI6 Info
  Van Hunt (formerly Transit Tuning) Magenta Sunset 17 12,836 28-05-2018, 07:08 PM
Last Post: Magenta Sunset
