Air Bag Light DOES NOT come on - Fail :(
Hi there, Im currently trying to get my car on Spanish plates and it failed because the Airbag light doesn't come on with the first turn of the key... I have read that a flashing airbag light is a common fault in the peugeot 306 (mine is a peugeot 306 1.4i).
Do all you people with experience of this think that perhaps someone had the flashing Airbag light problem and then just took the bulb out? If so, how does one locate the bulb and put it back in? And then should I locate the connectors under the seats and get rid of them and just solder them together? Assuming that is the reason the light isn't coming on at all? Presumably the light should come on after the first click of the key in the ignition?? Please help!
dash light sequence for my GTI6 i guess it will be the same for the 1.4
GTI6 Info
  Brake light switch fail again! Jimmyboycheck 7 5,474 14-12-2012, 05:29 PM
Last Post: Jimmyboycheck
