Threads: 169
91
Car Model/Spec: 2003 Jaguar S-Type Sport 3.0V6
Given 1 thank(s) in 1 post(s)
(11-08-2014, 12:15 AM)Dum-Dum Wrote: They don't look as bright on the car as they did on the bench.
They're conspicuous, don't worry
Threads: 591
54
Pah, 4pots. Need 6 pots
Threads: 169
91
Threads: 62
10
Car Model/Spec: Golf 7 GTD : LBSC Rallye
Given 11 thank(s) in 11 post(s)
How are you getting on with this Niall?
HDi Owner for 200k/9 years
Threads: 581
195
Great. Its running a bit rough at the moment due to the fact the charger is literally eating its self and heating the air badly.
[attachment=18608]
As you can see from that, after 40, it starts dropping right off. Because the charger rotors are rubbing together, 45 degrees is about average for this car! Im really pissed off with my self that i didn't rebuild this charger when i knew it needed it. Its now cost me another charger. I could get it refurbed but i would need the rotors recoating at about 400 quid. I have read things about having them shot blasted and powder coated but dont want to try it my self.
Next thing is to Get a new charger which doesn't sound like a clattery old diesel and then start making it all a bit more efficient. Should see 230 with a few small changes
Threads: 476
81
Car Model/Spec: 306 Rallye
Nice one Niall. Keep at it. You can show me all this software once I've got my act together and got a laptop and cable!
Threads: 169
91
(26-08-2014, 07:59 PM)SRowell Wrote: Nice one Niall. Keep at it. You can show me all this software once I've got my act together and got a laptop and cable!
And got your car back together
And got it running properly
And put the right fuel in it
And get round to driving it
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
Given 16 thank(s) in 16 post(s)
26-08-2014, 11:00 PM
(This post was last modified: 26-08-2014, 11:01 PM by Stef205.)
If he had any sence he'd rebuild the snout on the new charger. Am i allowed to say that your charger is cute yet? Maybe this time dont feed the snout castrol 15w/40 oil haha it might like some propper stuff.
Threads: 581
195
Charger rebuild kit will be on order tomorrow
Yeah can do because I don't have a 40000hp rotrex Honda and have an inability to use a clutch properly
Also, the 10w/40 did it good thank you. It quietened right down after I filled it with that lol
Threads: 106
7
Car Model/Spec: GTi-6
Given 0 thank(s) in 0 post(s)
You can see in the map it starts pulling ignition timing pretty sharply after 30*c. Also, from the dyno time I've had over the last few months, it doesn't take much spark retard to totally nuke the power. I found on mine that pulling 5 degrees out would lose about 10hp at peak!!
Does it also pull the fuelling out too on the injection table in a similar manner? I'd imagine so, or it would go mega mega rich.
JP
JP
Threads: 581
195
It does yeah hence why it's been feeling so bloody slow of late (well slower lol). With the IC I'm using and a healthy charger, 25 degrees should be the top of what I see really. Even on my first mapping session when I had the pikey twin pass I saw no more than 32 so with the new setup and a healthy charger we should be back on form. Considering it was knocking slightly when on the dyno, I suspect there is probably a few extra hp to be had out of this car but I know they were having real troubles keeping the air temps down when they were mapping it. For the last hour they were literally pumping air conditioned air straight down it's neck and still struggling to stay below 35ish!
Threads: 106
7
Yeah, so the charger has turned into more of a heat pump than anything else then!!
When you say knocking, do you mean det or bottom end knock?
Are you going to stick with the same size charger, or go bigger? Out of interest, is it the m62 with electronic clutch? I may have a spare one here for the Cupra TDi build that we haven't ended up using.
JP
Threads: 581
195
No the charger is knocking due to the slack in the drive gears.
I'm using the M45 from a merc and will stick with that because it will just bolt straight on so it's just easier. The M62 is basically the same as the m45 just with a different body and clutched pulley.
Threads: 6
1
Car Model/Spec: Yes, lots!
Given 2 thank(s) in 2 post(s)
Now then Niall!
I'm sure you're aware but your fooked charger will be blasting it's guts into your engine....
Be an idea to go for an m62 whilst you're changing the charger? You could swap the clutched pulley and nose for your m45 nose/pulley. From memory it's pretty easy to swap, just one of the nose gears needs modding to take dowels to drive the plastic coupler
Threads: 581
195
Glad to see you have come to the dark side Allen!
What's the benefit of the M62 over the 45? Iirc displacement is the same and other than the charger being physically more compact, I can't see a benefit?
That said, I'm pretty sure the bolt pattern for the snout is identical through all m45 chargers so should in theory be able to just bolt my snout on with the smaller non clutched pulley.
Or are you just trying to get me to use a m62 because you know you will get more work for a new outlet?
Threads: 6
1
27-08-2014, 11:12 AM
(This post was last modified: 27-08-2014, 11:13 AM by allanallen.)
Haha! Yep just after the work
From memory M45 displaces .75 litres a rev, m62 is 1 litre
It's all dependant on finding a good used one mind!
Threads: 106
7
Yeah, M45 displaces 750cc, and M62 is just over a litre...
Mooooreeee boost!
JP
Threads: 6
1
Or same boost more power
Threads: 581
195
Ah ok, will have to look into that then. I've found a few tech drawings of the two chargers and the bolt pattern is identical between my charger so I could use my snout on a M62 and just sort the new drive gear.
JP, text me about this charger you have sitting about
Allen, if I get one and decide to go for it I'll be in touch for a quote!
Threads: 541
124
YAY bigger charger
Threads: 117
119
Thought you said you were going for more boost, let down. :p
Threads: 28
1
Twin charge it and don't be a speccy wizard!
Threads: 26
0
Threads: 581
195
So, got the old charger off. Its well and truly fooked
[attachment=18724]
[attachment=18725]
[attachment=18726]
On top of all of that, the nose bearings are shot to pieces which i think is what was causing most of the noise.
[attachment=18727]
Picked up the new charger which was just down the road. Bit of a bargain at £150 with a 3 month warranty and its mint. Few tiny marks on one of the rotors but you will always get that. No play anywhere at all. Only issue is the pulley needs swapping for my -19% one but i think the fact i should be seeing sub 25 degree temps should balance that out. On the old charger i was seeing 40+ and at about 35+ it retards the ignition big time!
Will get it fitted tomorrow and get some logs done. may get a few screen shots up on here if people are interested to see the sorts of things you can do with it!
Threads: 591
54
Good price dood.
Nice buy.
That one is truly buggered!!
Threads: 541
124
Good work dude. Can't wait to see you flying again. Will the warranty cover non standard fitments and smaller pulleys?
Threads: 581
195
Probably not
Its fitted and sweet as a nut. No more knocking noises, smooth to drive again and most importantly on a run, maximum air temperature of 28 degrees . It did go up in heavy traffic but i expect that and it cooled fairly rapidly once on the move. Only issue is I'm using the standard huggeee pulley which has dropped the maximum boost down to 3psi lol. Need to get my smaller pulley on so i can be back up to 6 - 6.5psi and with the decrease in air temp, i should see a fair gain over the 215bhp figure i was given when it was mapped.
Threads: 476
81
Good progress mate. hope this one lasts a bit longer than the previous ones!
Threads: 541
124
Good drop in temp mate. I won't make you jealous by telling you my inlet temp lol
Threads: 581
195
(01-09-2014, 07:48 PM)Dum-Dum Wrote: Good drop in temp mate. I won't make you jealous by telling you my inlet temp lol
You won't make me jealous mate. Ive been well aware from day one that Eaton chargers aren't all that efficient when it comes to heat. If i wanted something blowing cold, i would of bought a Rotrex....but then id be just like everyone else lol.
anything below 35 is manageable and even when moving i could bring down the temps to probably the high teens by using water/meth injection which I'm considering over winter.
