Fuel pump no prime car cut out
I was driving this morning about 15mins then the car started to cut out I thought straight away the fuel pump.
It was a few weeks ago on a very hot day. I had to press the red botton inside engine to re set fuel pump not sure why. It worked after that but today it's stopped priming.
This fault code come up lp fuel pump?
306 hdi thanks[Image: 3272088b29dd1ad4cad9bbcc5e297842.jpg]
Sent from my GT-I9505 using Tapatalk
Hello does this fuel lp pump fit and are they any good do people know?[Image: 60f27c6aa5d69758f10a8fef3c5e0726.jpg]
Have you tried bridging out the red button, might not be the pump itself?
(15-05-2018, 07:47 AM)Toms306 Wrote: Have you tried bridging out the red button, might not be the pump itself?
Hello how do you do that thanks
so long as you are aware it's an impact sensor to cut the fuel supply in a crash.
Hate Housework!
Literally just unplug it and put a wire/unbent paperclip into the two pins. This is purely for testing the switch and not a long term solution as it's a safety feature as above.
nicely put ThumbsUp
Hate Housework!
I bought a lp fuel pump from euro car parts 9.30am it was deliver to my work place before 12pm. I've fitted the part my self and the car works fine now genuine vdo £103 so I can drive home from work now.
(15-05-2018, 12:14 PM)Welshy_Pete Wrote: I bought a lp fuel pump from euro car parts 9.30am it was deliver to my work place before 12pm. I've fitted the part my self and the car works fine now genuine vdo £103 so I can drive home from work now.
RESULT! Smile
Hate Housework!
  306 hdi fuel pump relay Fireblade999 3 3,679 20-06-2018, 06:47 PM
Last Post: Fireblade999
  Replacing the fuel pump gromit190 8 6,710 29-01-2018, 11:59 AM
Last Post: gromit190
  Fuel pump/sparks plugs Seid' 0 2,487 08-10-2016, 04:19 PM
Last Post: Seid'
